fabia 2003 knock sensor help
Hello everyone
I have purchased a new car, Skoda Fabia 2003 Combi.
I checked sensor connections and found a knock sensor Not connected.
and i found the connectors is cut.
i found this on internet
and i buy new knock sensor,But the sensor has only 2 pin.
What is the use of the black line in the picture?
Is it the ground?
:blink::blink::blink:
Edited by hussien95
  • Sponsor
It's the cable screen/shield.
Thank you for your response.
I read about this, (as a shield).
But what do I do with this wire?
Do I make it without a receipt? Or connect it to the ground?
Because, as I said befor, the connector was cut.
Shield/screen should always be grounded. It's to protect the delicate signal from EMI.
thank you very much all.
I will connect it to the engine block.
