Trim clips
Would someone be able to confirm the exact type/size of the clips used to hold the boot trim please?
Tom
Are you talking about the big plastic panel on the inside of the boot lid?
If so there are 2 sixes. Brought some a year or ago off eBay.
Nothings ever easy is it?
Yes, it is the big trim piece that covers the wiper motor etc. Didn't realise there are two sizes, they all looked the same.
Tom
I could be wrong but looking on eBay, these could be the ones. 16mm and 22mm
  http://www.ebay.co.uk/itm/191069924741
And
http://www.ebay.co.uk/itm/371795005561
I could be wrong but pop the trim off and have a look. From what I can remember the bigger clips sit around the outside.
The clips did slide around and occasionally slide out of the boot panel, I bent the ends up so they didn't fall out.
Think it's more to do with the way the spring clips slide into the holders on trim rather than size. The outer slide in one way ant the two inner ones slide in an other but have cut outs on the base to keep them the same direction.
