[HELP] Right headlight and right blinkers not working
Hello!
I got a skoda octavia 2011. The front right headlight and indicator on mirror and front is not working. Back lamp and indicator is working great. Only things that's working on the front headlight is "parking light" This is pretty weird issue. Would really appricate all the help! Thanks!
It could be anything - you need to start with the basis
1) check the bulb and led light - it might be coincidence and they have failed together
2) check the security of connectors on each component
3) has the BCM been coded recently?
4) check wiring between BCM and indicators
The list goes on........
Hello! I checked the brown and black cable on the headlight i guess (main power)? And it doesn't give any power at all. Does it have any realays under the dashboard ?
Edited by leosef
Check the fuses, some maybe refer to your problem...
Not sure if any fault scanning can also help..
I Checked the fuses, can't really find which one is for the headlight. Scanning didn't help at all, no faults found.
What did you scan with? If any bulb isn't working then I'd expect at least a bulb out warning shown in VCDS.
With Delphi and another one named "Autel"
It might be worth trying to find something VAG specific such as ODIS or VCDS. Even OBDeleven might show something :)
I have the Delphi tool and it's pretty good with VAG
It can do coding and adaptation channel changes just like VCDS and obdeleven.
providing you carried out a full global scan and it's not a Chinese fake copy, it would have picked up a fault if 1 was stored.
