Allot centre cap removal
If you don't care about the current caps and are changing them anyway do what I did and just pry behind the 'sticker' of the front of the cap (mind the actual alloys) and bend it out towards you a bit so it's like half stuck and half bent up, from there you've got enough play to just yank them off.
Use a stick of hot glue, melted a little, press against cap, allow to set. Go round all the wheels, start again, pulling off caps the peel off glue again.
Of course, if you are removing them to bin, even easier. Drill or screw a screw part way in to them and pull with pliers!
Edited by mrgf
