Hollow VRS Door???
On my Furby Vrs the front passenger door sounds hollow like there is not impact bar, the car is going into the dealers on Monday because it has a loose handle on the outside of the same door, has anyone encountered a similar problem with their skoda??
All doors have a strengthening bar from the front to back about half way up. If the handle is loose, that could be just that the bolts holding it together from the inside have come loose, but it shouldn't have happened.
Did you buy the car new?
Hi, bought the car second hand in december its an 05 model with 6500 miles on the clock, the handle is not so much loose ie can wobble it its like their is no resistence from the handle when you open the door ie not spring loaded??
The door sounds hollow when you tap it and sound tinny when compared say to the drivers door and my mates vrs passenger door which has like a dull thud, same as my other 3 doors, im wondering if the car has been tw**ted at some point in its short life
