Destination delete.
How do you delete obsolete destinations please.
I've read page 57 in the manual and it says a delete icon comes after you select edit. Here's the problem I can't get an edit icon on screen. I'm sure i've followed the instructions to the letter but no joy. Amundsen satnav.
Come on chaps. All input gratefully received.
I've just had a look at the Online Manual and the Nav Settings are on Page 128. Page 57 talks about the Electric boot.
Any help
Manage memory
› In the Navigation main menu, tap on the function surface → Manage memo- ry.
■ Sort Contacts: - Setting the arrangement of the phonebook ■ By surname - Sorting by the contact surname
■ By first name - Sorting by the contact first name
  • Define home address - Enter the home address
  • Delete My POIs - Deleting own POI categories (Personal POI)
  • Update My POIs (SD / USB) - Import / update your own POI categories (Personal
    POI)
    ■ Import destinations (SD/USB) - Import destinations in vCard format
    ■ Delete user data - Delete user data (by pressing the function surfaceDelete and
    confirm the deletion)
    ■ Last destinations - Delete the last destinations
    ■ Dest. memory - Delete the stored destinations
    ■ Routes - Delete saved routes
    ■ My points of interest (Personal POI) - Delete the custom POIs
    ■ Entered cities - Delete the history of places already entered via the address
    ■ Home address - Delete the stored home address
    ■ Flagged destination - Delete the flagged destination 
Cheers mate.
I found that bit but thought there may be a way to delete one by one as don't want everything gone.
2 hours ago, Goldyy said:
Cheers mate.
Sorry I can't be more helpful , my Vrs with the Admunson sat nav is in the menders other wise I'd have had a play with mine.
There must be a way to do it.
-OFF-TOPIC-
Not contributing at all for this thread, but every time I read the title, I think of this :)
Buggered if I can find a way.
On the bottom of the screen there is a route/new route or my destinations tab. If you open that up is there a sub section. If you then select a stored route you open that up does it not give you the option to delete/edit/alternative route or delete it.  I'm sure I've deleted/cleared routes one by one.
Depends how the destination has been saved, far as I can tell for 'Last Destinations' it's all or nothing.  Mine is Amundsen 1, if saved to 'My Destinations' then possible to delete independently.
Select Dest & Contacts >  Dest Memory from drop down tab > touch arrow to right of the destination you wish to delete then Edit to get the Delete option.
Cheers mate that's done it. What a stupid system having to save before you can delete.
Good to hear it helped.
Maybe it's me but seemed fairly logical bit like a web browser.  Last destinations is like history, can delete everything but not individually, my destinations more like bookmarks / favourites.
Edited by Skaut
