Security code for ABS module
Hi guys needing help to code abs module or someone that can produce code for me in a 2010 skoda octavia 1.9tdi 5 door, I have 16.8 vcds and also have vehicle- specific information but I don't know how to produce the 5 digit code that is required to program abs module or produce the soft coding either from that info please help and thanks in advance to all that help me thanks. I put a new abs module in the car which turned off the abs, esp and flashing handbrake light which I had with the previous module. The following morning I turned car on and light were back on, I went into vcds and it said that the abs module was incorrectly coded so went security access and it's asking for 5 digit security code which from my understanding you get from the car specific information list which I have but can't work out code
Edited by paulh43
Firstly, you should update your VCDS version.
Secondly, have you got an autoscan from before you replaced the ABS module? Can you post it?
Thirdly, can you post a current autoscan?
Can you also confirm the part numbers of the old and new ABS modules? Why were you replacing the old module?
