OE Coil Springs for Vrs Estate
Reading the forums I can see an lot of mention to Bilstein B3 OE springs, Lesjofors, Sachs etc but the matter gets a little murky when the discussion is on a VRS model with the sports suspension.
I have a 2010 FL Vrs 2.0 TDI Estate and previously I have used TPS to get the right spring in fear of getting the wrong ones from motor factors etc and ending up with higher ride height.
Last time i looked at this was about 3 years ago so things may have changed but there still seems to be ambiguity in the part numbers from OE suppliers as to what is a direct replacement for the VRS Estate. Is it the case that there is still no decent alternative to the £75+vat each spring from TPS only? If anyone has any experience with OE parts and has the part number used for a FL VRS estate I would be keen to find out.
Thanks.
or just a thought ..stick it on sportlines,  better than stock and about the same price
PM me your reg, I can check Skoda ecat for part numbers.
Cheers, will do!
