fabia vrs abs fault? HELP
a couple of days ago i changed my rear tires and when i drove away the car heasitated and didnt run any more than 30mph ish...
when i turnded my esp of it ran like normal but my abs is on any time i break.
what can it be?
resently swapped one bearing can this cause the problem?
any thoughts is helpfull and sadly i cant scan the abs system with my computer:(
can you measure the sensor somhow at the abs harness?
best regards dennis.
Did you fit different sized tyres to the rears than are on the fronts?
Even a small difference in size will confuse the ABS ECU.
yes it is exactly the same sadly...
  • Sponsor
Which bearing was changed?
Then the wheel bearing is not correctly fitted.
Resor right was fitted 3 weeks Ago tho. Tourced right and so on :(
  • Sponsor
Don't think it's possible to mis-fit the rears. Fronts are a different matter.
Thought so too there is a ton of rust and brakedust on the left one.
Can that cause the problem?
