Kodiaq Reversible Boot Mat 3" too small
Does anybody know why the double sided boot mat for car with spare wheel ( part No. 565 061 163A ) is about 3" too short?
See attached photo's
It's sort of all right with rubber side up but with textile finish up it slides forward and backwards. But for £91.00 I would expect a good fit.
vizslabob
Edited by vizslabob
missing word
It might be that it is designed for the 5-seater. Therefore the fit isn't perfect in the 7-seater.
I think Boxerboy posted something to that effect in this thread.
Yup, it's made for the 5 seater.
I have tweeted Skoda UK have had the "will look into it" reply You might be right on it being for the 5 seater. Mine is a 7. It is listed for the 7 seater on Skoda car configuration web site.
I have in in my 5 seater and it's a perfect fit.
yes it seems its only a problem on the 7 seater
Yep, ours is the same. I'm hoping our hound will sit on the rubber bit. I suspect though she'll curl up in the corners and distribute her fur evenly over the exposed bits of the third row seat backs and first aid cubby hole.
Just found a good solution from German supplier.
It fits very well after heating up with hairdryer as instructed.
The centre portion has an anti-slip soft finish which is good to stop luggage and dogs sliding around.
http://www.ebay.co.uk/itm/302401557753
I followed suit and have now fitted the much bigger plastic liner.
It seems a thinner construction than similar looking mats that I've used in previous cars.
Delivery was very prompt and I was relieved that it flattened out after a coup!e of days under a bed, because it was rolled up quite tightly.
The only niggle in the 7 seater of course is having to leave the mat at home when using Row 3 seats.
More of a nuisance if you didn't plan on using the seats when you left home.
