DSG Fault Codes
Hi,
Ran a scan via OBDEleven of my car this morning and it came back with a range of faults on my DSG box. Should I be worried about these?! Anyone seen similar with VCDS/OBDEleven?
Thanks,
02 Transmission
    System description: DQ250-6F MQB
    Software number: 0D9300040L
    Software version: 4002
    Hardware number: 02E927770AN
    Hardware version: H52
    Serial number: ---------------------
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
        P072C00 - Stuck in Gear 1
            Intermittent
        P072D00 - Stuck in Gear 2
            Intermittent
        P072E00 - Stuck in Gear 3
            Intermittent
        P072F00 - Stuck in Gear 4
            Intermittent
        P073A00 - Stuck in Gear 5
            Intermittent
        P073B00 - Stuck in Gear 6
            Intermittent
        P072B00 - Stuck in Reverse
            Intermittent
        P174A00 - Partial transm. 1 valve 3 Electrical error
            Intermittent
        P174E00 - Partial transm. 2 valve 3 Electrical error
            Intermittent
        P072600 - Engine Speed Inp.Circ. Range/Performance
            Intermittent
            Intermittent
        P179D00 - Cooling oil valve Electrical error
            Intermittent
        P173400 - Starter release from the selector lever sensor system
            Intermittent
Never seen these on any of the DSGs I have had but have you noticed any issues whilst driving?, if not clear the codes and see if they come back, if they do = dealer visit
I haven't noticed anything specific, apart from sometimes it seems a bit clunky dropping from 2nd to 1st. I'm booked in for a service next Friday so tempted to leave the codes there and ask them to investigate whilst it's in.
Did you scan the car while the engine was running?
If you did then it's probably nothing to worry about, clear the codes and run it again with the engine off.
I have exact same errors for a long time. I guess you can expect this problem as well:
My dealers still havent do anything about it.
To the OP, those codes suggest the shift solenoids in the mechatronics unit are faulty, plus the selector lever assembly needs replacing.
Toni8B
Well they should replace the shift selector mechanism, as it's a fairly well documented error.
Edited by MoggyTech
reasons
Thanks all who posted. I've had the selector error fault for some time and the code keeps coming back after being cleared so will raise this.
Thinking about it the engine might have been "on' with start stop active as I'd just parked up which may account for some of the other codes I haven't seen before.
Edited by ahenners
5 hours ago, MoggyTech said:
Toni8B
Is there a place where this documentation can be seen?
Dealer should have it listed as 'fairly' common problem. There was never a recall but the techs should definitely know if this issue.
Problem is engine is OFF! Run engine and there wil bee no errors.
Toni, I'm sorry to hear still not sorted. The other thread has my dealer details. Hopefully they can talk to your dealer & help you out?
Cheers,
Dunc
I guess its all about chasing your warranty, at least where I live..
Yes. It's a known fault for both VW & Skoda. There's a TPI.
It should be fixed without question.
  • 2 years later...
