How to find part numbers?
I really need to find some part numbers. I'm needing the plastic trim/bezel that goes around the edge of the NS door mirror, and I'm needing a replacement mirror glass. I'm also needing a door handle trim for the NS rear door. I can't for the life of me find the part numbers in order to order these from somewhere that's not the dealer...
1 hour ago, peter_k said:
Those part numbers are for the Superb MKII (3T).  The MKIII will have part numbers starting 3V.
If you still have access to the old parts you need to replace then the part numbers will be printed on them otherwise good luck finding a source for MKIII part numbers as I've looked before and failed miserably.
Thanks for that info  - I would have thought I'd have seen this mentioned in the forum earlier.
It looks like this question was also asked in February - Here's RickTT's reply https://www.briskoda.net/forums/topic/424668-mirror-replacement/?tab=comments#comment-4818064 that includes "3V" bezel part numbers
