Diesel fuel pump on '51 TDI 1.9
Dear All
My Octavia packed up today. I had just started out on the dual carriage way, flicked the cruise control on at 75MPH and then the power just died. Fortunately, I was able to freewheel down an exit lane out of harm's way.
The Green Flag man did his checks and found there was insufficient fuel flow. He concluded that the fuel pump (mechanical) had probably failed with an outside chance the fuel filter might be the problem. I checked my records and found the fuel filter was last changed in May 13.  I spoke with a VAG specialist and he thought it was either the pump or the 'uplift' pump in the fuel tank and unlikely to be the fuel filter.
The car is a '51 plate and has 167,000 on the clock. Is this about normal for a car of this age and mileage?
I have booked the vehicle in for a thorough diagnostics check. Depending on the result, I have to decide whether to get it fixed or call it day.
Bit upset. Feels a bit like an old friend. It has never let me down and is in excellent condition for the age.
Any views on this are appreciated.
Martin
PS - Footnote to my original post.
The car has done 27,000 in the four years since the fuel filter was last changed.
Martin
Hi Martin, Pretty sure the pre- PD engines with the mechanical rotary pumps did not have a lift pump in the tank so not likeley to be that! What engine code do you have in your car? The old pumps were pretty bullet proof unless used with contaminated diesel or bio fuel but some of them had electronic components that could fail.
Peter
Peter
The engine number is ASV299452ASV
Thanks for your interest
Martin
That will be the 110 then
I doubt very much it would be the filter blocked although always worth draining it through the drain on the bottom in case youve got some water in the fuel (apparantly Tescos are well known for this!)
Firstly though get it scanned for fault codes as I am wondering wether it is coincidence that you say it died as soon as you turned the cruise control on, so maybe electrical???
If it is the internals in the mechanical pump it may not show up as a fault but at least you have a starting point.
A mate of mine owned a cab company and ran a fleet of vehicles with these engines and had no pump problems and they all went on to 300k plus miles no problems....but theres always the chance.
Having said that even if it is the pump you can source a second hand one for peanuts now and they are not rocket science to change ... cam belt off is the worst bit.
Also worth checking that you havent got a blockage somewhere between the tank and filter / filter and pump check none of the pipes have been kinked or damaged.
Let me know how you get on... you cant be far from me as I am just outside of Aylesbury so give me a shout if you need any help.
Peter
PS once you get a bit of air in the system on these engines they are an absolute pig to start so if you drain the filter make sure you refill it with diesel before you try to start it or it will just turn over forever, although you can bleed them by backing off the nuts on top of the injectors and spinning it over (This will also give you an idea if you are getting any diesel up to the injectors)
Peter
I am in Buckland next to Aston Clinton!
That is a really helpful post particularly as you have come to the same conclusion as me. Electrical. At the time it happened, all the warning lights came on and then everything died. Also, even stranger, the fuel warning light was on before the incident. 50 miles left in the tank. I was on my way to Hemel and usually top up at the Shell service station while I am over there. After gliding to a halt on the hard shoulder on the roundabout, I tried starting it and noticed that the fuel gauge had jumped from just above the red warning blob to nearly a third full. That is peculiar and must surely be an electrical problem. The Green Flag man added another gallon of diesel as a precaution with no change as to be expected. This is a problem 'related' to fuel flow not fuel shortage. I also note that when the car died I could hear a slight whining sound winding down. There are a lot of air bubbles in the fuel pipe when is being cranked over.
Since you are a local man, is there anyone in this area that you would recommend to do work on these cars?
Martin
 I am just down the road in Wendover! Afraid I cant recommend anyone locally as Im not originally from round here and tend to do all of my own maintenance and repair work (when I have the time!!)
Dont know if you have checked the fuses but looking through my owners manual fuses numbers 10,29 and 44 seem to be for diesel engine electronics and number 32 for diesel pump injection control?? worth a check before spending money!!
Peter
That's great.
I'll let you know how I get on.
Martin
Peter
I ended up checking every fuse in the box mounted at the end of the dashboard on the driver's side.
All OK.
However, during last week we had a downpour and the sunroof was left open on tilt.
The following day I noticed traces of water/damp around the area close to the hand grabs where the grey material covering the roof area inside joins the plastic sleeves on the front pillars. It dried out after a day or so. There are drain holes either side but the water must have had backed up at some point or been restricted by gunk inside the pillars. I feel sure this must be related.
We have the above, the engine dying when the cruise control was activated and the fuel gauge registering wasy above the level prior to the engine failure.
Could it be a short circuit that has not actually caused any fuses to blow? I did wonder whether damp got into the fuse box somehow as a result of the downpour but there are no signs of any moisture.
Martin
Sent you a PM Martin.
The following codes came up on a basic diagnostics check.
18062
17965
P1557
P1256
That's it. This was not a full VAG diagnostics test at this stage.
I am now searching the internet for similar symptoms which might relate to the above.
Martin
kentphil1
Thanks for the links. Really helpful.
I am beginning to build a picture here.
Just to get the last one out of the way which I do not think is relevant to the specific problem here but useful nevertheless. I have noticed that the engine temperature has been running slightly cooler than normal. I assumed the thermostat needed replacing. Also, the idle speed on startup can sometimes fluctuate and can get as high as 1000RPM before settling down and returning to normal idle speed.
We tried a 'booster pack' startup today as the battery was close to flat after the session with the Green Flag recovery man when it broke down. No sign of catching at all.
I now need to do some extra research on the links to the 17965 code concerning boost etc.
Do you have a link to the code 18062?
Martin
18062 is oil temp/level sensor defective
19 hours ago, Martin J said:
kentphil1
Martin
Here you go,
As above, 18062 is oil sensor issue
Quote
Fault table
  Note
t  On vehicles 08.98 ? different fault codes are displayed with the same or similar text. Select the required text in the fault table according to the fault code.
t  If “Info in literature” appears in the display of the vehicle system tester, look for the text required in the fault table under the fault code.
t  The fault table is ordered according to the fault code on the left.
t  Explanations on fault types (e.g. interruption/short-circuit to earth) → Operating instructions of vehicle system tester.
t  If parts are output as faulty: First test all of the cables and plug connections to these components as well as the earth cables of the system according to the current flow diagram. Only if no fault is detected here should the part be replaced. This applies particularly if the fault is shown as sporadic (SP).
Display -V.A.G 1552-
Fault number Possible cause of fault Possible effects Fault
elimination
old new
00513 16705
Engine speed sender -G28-
  implausible signal
t  Sender disc bent or loose
t  Clearance of rotary speed sender/sensor rotor too great
t  Metallic swarf on engine speed sender -G28-
t  Line interruption of the screening
t  -G28- defective
t  poor starting
t  irregular engine running, misfiring
t  increased idling speed
t  Preheating warning light flashes
t  reduced performance
t  No display on rev counter
t  Engine does not start
–  Remove noise insulation and test sender disc.
–  Check engine speed sender → Chapter.
  no signal 16706
t  -G28- defective
t  Line interruption or short-circuit
00519 17563
Intake manifold pressure sender
-G71-
  Short circuit to positive
t  Short circuit to positive
t  -G71- defective
–  Check intake manifold pressure sender -G71- → Chapter.
–  Inspect intake system for leaks.
  Open circuit/Short-circuit to earth 17564
t  Line interruption or short-circuit to earth
t  -G71- defective
  Supply voltage 17565
    17566
00522 17663
Coolant temperature sender -G62-
  Short circuit to earth
t  -G62- defective
t  Line short-circuit to earth
t  Black smoke when starting
t  Engine preheating not operational
t  preheating always occurs for approx. 20 seconds
–  Test coolant temperature sender → Chapter.
  Open circuit/Short circuit to positive 17664
t  -G62- defective
t  Open circuit or short circuit to positive
00527 17568
Intake manifold temperature sender
-G72-
t  -G72- defective
–  Test intake air temperature sender → Chapter.
  Open circuit/Short circuit to positive 17569
t  -G72- defective
00532 18008
Supply voltage
  implausible signal
if necessary
t  Control unit was fitted on with the ignition switched on
–  Erase fault memory and observe vehicle → Chapter.
Voltage supply tml. 15
  Voltage too low
t  No voltage when iginition on (Terminal 15)
t  Engine stoppage
–  Testing voltage supply for diesel direct injection system → Chapter.
–  Testing voltage supply on terminal 15 → Current flow diagrams and Fitting locations.
t  Engine control unit -J248- defective
t  Diesel direct injection system relay -J322- defective
–  Replace control unit → Chapter.
00539 17570
Fuel temperature sender -G81-
t  -G81- defective
t  Increased emission levels
–  Check fuel temperature sender → Chapter.
  Open circuit/Short circuit to positive 17571
t  -G81- defective
t  Disconnect plug connection for injection pump
t  several faults stored
t  Engine stoppage
–  Test plug connection for injection pump.
00542 17653
Needle lift sender -G80-
t  -G80- defective
t  rough engine running
–  Test needle lift sender → Chapter.
  implausible signal 17654
t  Fuel feed interrupted (has been): Tank empty, feed line or filter clogged, system draws in air
t  possible fault 00550 injection commencement control, control difference stored
t  Misfiring, Jerking
–  Test fuel system.
t  (Sporadic) line interruption to fuel shut-off valve
t  Engine stoppage
t  Misfiring
–  Test cable connection and plug connection on the injection pump.
t  Sender disc of engine speed sender bent or loose
t  Mirfiring exactly at 3000 rpm
t  -G80- defective
t  Misfiring, jerking (in particular at a higher engine speed)
–  Replace needle lift sender.
t  Injection pump defective
t  Fault 01268 metering adjuster -N146- stored
t  no throttle after trailing throttle
–  Replacing injection pump → Chapter.
  Open circuit/Short circuit to positive 17655
t  -G80- defective
t  sproadic line interruption (cable fracture)
00550 17656
Injection commencement control
  Control difference (deviation)
t  Injection commencement N.O.K.
t  Loss of power at a higher engine speed
t  Engine starts poorly
–  Dynamically testing and setting the commencement of injection → Chapter
t  Adjustment path of the injection pump blocked (dirt, swarfs)
–  Inspecting the injection-timing range → Chapter.
t  Engine stalled (within the last 50 starts)
–  Erase fault memory, observe vehicle → Chapter.
t  possible fault 00542 needle lift sender implausible signal stored
–  Test fuel system.
t  Line interruption to commencement of injection valve - N108-
t  Engine jerks when idling, because the commencement of injection is constantly on “early”
–  Testing commencement of injection valve → Chapter.
t  possible several faults stored
–  Test fuses.
t  Injection valve -N108- worn
t  no constant commencement of injection possible during “basic setting” (display field 2 fluctuates, more than 10 displays)
t  irregular engine running, poor performance
–  Replace commencement of injection valve.
00553 16485
Air mass meter -G70-
  implausible signal
–  Erase fault memory, observe vehicle again → Chapter.
t  Battery weak
t  displayed air mass in measured value block
–  Check the battery.
t  sporadic line interruption (cable fracture) to needle lift sender -G80-
t  possible Fault 00542 needle lift sender, input open or interruption/short circuit to positive
t  Air filter blocked
t  Vacuum piping of exhaust gas recirculation is incorrect or mechanical exhaust gas recirculation valve is always open
t  irregular idling, poor performance
–  Inspect vacuum hoses → Chapter.
t  Air mass meter faulty
t  Poor performance. jerking
–  Test air mass meter → Chapter.
  Open circuit/Short-circuit to earth 17552
t  -G70- defective
t  possible Black smoke when accelerating from low speeds
  Short circuit to positive 17553
t  -G70- defective
  Supply voltage 17554
00575 17958
Intake manifold pressure (charge pressure)
t  Hoses interchanged, not fitted on, clogged, leaking
t  Pressure box of turbocharger defective
t  Charge pressure control solenoid valve -N75- faulty
t  sudden performance interruption
–  Test charge pressure → Chapter.
–  Check charge pressure hose → Chapter.
00625 16885
Vehicle speed signal
  implausible signal
t  Line interruption between speedometer sender -G22- and dash panel insert
t  -G22- defective
t  Speedometer -G21- defective
t  Line interruption between dash panel insert and engine control unit
t  CCS not operating
t  Air conditioning system not operational
t  possible load change jolts
t  Speed display N.O.K.
–  Testing the speed signal → Chapter.
–  Test speedometer sender → Electrical System → Rep. Gr.90.
Vehicle speed signal 17948
  Signal too high
00626 18024
Glow period warning light -K29-
t  Glow period warning light not operational
  Open circuit/Short-circuit to earth 18025
t  Line interruption
t  Bulb defective
–  Test glow period warning lamp → Chapter.
t  Short circuit to earth
t  Glow period warning light lights up and remains lit
00668 18009
Onboard voltage
terminal 30
  implausible signal
t  Diesel direct injection system relay -J322- jams
t  Diesel direct injection system relay -J322 defective
t  Engine does not start (safety deactivation)
00671 -
CCS switch -E45-
  undefined switch status
t  E45 defective
t  Cruise control system is deactivated
–  Testing cruise control system → Chapter.
00741 -
Brake pedal monitoring
  implausible signal
t  Switch is incorrectly set
t  Line interruption
t  -F- or -F47- defective
t  Fuse defective
t  both brake lights defective
t  Fuse or brake light defective
–  -F- and -F47- testing and adjusting → Chapter.
–  Test fuse and brake light.
00765 17762
Modulating piston movement sender -G149-
  Electrical fault in the circuit
t  10-pin plug connection for injection pump disconnected
t  Engine stoppage
t  Poor vehicle handling
t  Engine stoppage
–  Test modulating piston movement sender → Chapter.
00777 18039
Accelerator pedal position sender -G79-
  Signal too high
t  Line interruption
t  -G79- defective (idling switch)
t  Safety control to approx. 1100 rpm
t  no throttle
–  Check accelerator pedal position sender → Chapter.
  Supply voltage 18040
  implausible signal
if necessary
18047
t  Line interruption
Accelerator pedal position sender 1/2 -G79+G185-1)
  implausible signal
  Short circuit to positive -
t  -G79- defective
1) Incorrect fault text display. The correct display is: Accelerator pedal position sender -G79-.
elimination
old new
01028 -
Blower relay
-J323-
t  Line interruption
t  Relay -J323- defective
t  Fan afterrun without function
t  Radiator fan always on
–  Test signal for radiator fan → Chapter.
01044 18020
Engine control unit incorrectly coded
t  invalid control unit coding
–  Code the control unit → Chapter.
01117 17911
Load signal for alternator terminal DF
  implausible signal
t  AC generator defective
t  Voltage regulator defective
–  Testing the wiring
–  Inspect AC generator → Current flow diagrams and Fitting locations.
01180 -
Engine/air conditioning compressor electrical connection
t  Short circuit in the wiring
t  reduced vehicle acceleration, when the air conditioning system is on
–  Testing signals from/to the air conditioning system → Chapter.
01193 19460
Low heat output relay -J359-
t  Line interruption
t  Low heat output relay -J359- defective
t  Engine preheating always on
–  Test wiring → Current flow diagrams and Fitting locations.
–  Test low heat output relay → Chapter.
  Short circuit to positive 19459
01194 19462
High heat output relay -J360-
t  Line interruption
t  High heat output relay -J360- defective
–  Test high heat output relay → Chapter.
  Short circuit to positive 19461
01237 17945
Fuel shut-off valve -N109-
  Malfunction (mechanical fault)
t  -N109- defective, leaktight or jams
t  Engine stoppage
–  Check -N109- → Chapter.
  Open circuit/Short-circuit to earth 17946
t  -N109- defective
t  Engine stoppage
01262 17954
Solenoid valve for charge pressure control -N75-
t  Charge pressure too low
–  Inspecting charge pressure control solenoid valve → Chapter.
  Short circuit to earth 17955
t  Charge pressure too high
  Open circuit/Short-circuit to earth 17957
t  Line interruption
t  Solenoid valve defective
01265 17810
Exhaust gas return valve -N18-
t  no exhaust gas recirculation
  Open circuit/Short-circuit to earth 17849
t  Line interruption
–  Testing exhaust gas recirculation valve → Chapter.
t  too much exhaust gas recirculation
t  reduced performance, black smoke
01266 18026
Glow plug relay -J52-
t  Glow Plug System not operating
–  Test glow plug relay -J52-.
  Open circuit/Short-circuit to earth 18027
t  Line interruption
t  Relay defective
–  Test glow plug relay and wiring → Current flow diagrams and Fitting locations.
t  Glow Plug System constantly on
01268 17969
Metering adjuster -N146-
t  Engine stoppage
–  Test metering adjuster → Chapter.
  upper limit value 17970
t  Metering mechanism adjusted
t  Jerking, loss of power
  lower limit value 17971
t  Black smoke
t  irregular idling
01269
Commencement of injection valve -N108- 17659
t  Engine jerks when idling, because the commencement of injection is constantly set to “early”
  Open circuit/Short-circuit to earth 17660
t  Line interruption (fuse)
t  Valve defective
–  Test fuse.
t  Loss of power, because the commencement of injection is constantly set to “late”
01282 19561
Changeover valve for intake manifold flap -N239-
t  Line interruption
t  Changeover valve for intake manifold flap defective
t  hard engine switch-off impact
–  Test the change-over valve for intake manifold flap → Chapter.
  Short circuit to positive 19560
16500 -
  implausible signal
t  Coolant temperature sender -G62- supplies implausible signal caused by loose contact or corrosion due to humidity in the connector
t  Cold-start difficulties at very low temperatures
t  Poor driveability during warm-up
t  Increased fuel consumption
–  Read measured value block, display group 007 → Chapter.
–  Coolant temperature sender -G62- → Chapter.
t  Signal input in engine control unit defective (control unit defective)
–  Replace engine control unit → Chapter.
t  Coolant regulator defective
–  Check coolant regulator → 1.9 ltr./81 kW Engine, Mechanics → Rep. Gr.19.
16955 -
Brake light switch -F-
  implausible signal
t  Brake light switch defective
t  Line interruption or short-circuit to positive or earth between the brake light switch and the engine control unit
t  Brake light does not light up
t  Engine speed fluctuations during braking
–  Test brake light switch and brake pedal switch → Chapter.
17811 -
Exhaust gas recirculation system
t  Exhaust gas recirculation valve -N18- defective
t  Exhaust gas recirculation system not operating
  Control difference
t  Exhaust gas recirculation potentiometer -G212- defective
t  Mixture adaptation not operational
–  Inspect exhaust gas recirculation valve → 1.9 ltr./81 kW Engine, Mechanics → Rep. Gr.26.
17931 -
Crash signal from airbag CU
  implausible signal
t  Fault in the airbag system
t  Airbag warning light lights up
–  Test airbag → Body Work → Rep. Gr.01.
17964 -
Boost-pressure control
  Regulating limit not reached
t  Fault in charge pressure control
t  -N75- defective
–  Inspecting charge pressure control solenoid valve -N75- → Chapter.
–  Check charge pressure control → 1.9 ltr./81 kW Engine, Mechanics → Rep. Gr.21.
17965 -
  Regulating limit exceeded
t  -N75- defective
17977 -
CCS switch -E45-
  implausible signal
t  CCS switch defective
t  Line interruption
t  CCS not operating
–  Reading measured value block 006 → Chapter.
17978 -
Engine control unit blocked
t  Manipulation attempt
t  Start attempt with unauthorised ignition key
t  Engine control unit not adapted to immobilizer
t  Engine starts and stops immediately
–  Adapt engine electronics control unit to immobiliser → Electrical System → Rep. Gr.90.
t  Short-circuit in communication cable
t  fault in the immobilizer system
–  Test immobiliser → Current flow diagrams and Fitting locations.
t  Immobilizer control unit defective/missing
t  Engine control unit incorrectly coded
–  Code engine control unit → Chapter.
18044 -
Data bus drive
  missing message from airbag control unit
t  Datalines faulty
t  an ABS fault is present
–  Test data bus → Chapter.
–  Test airbag control unit → Body Work → Rep. Gr.01.
18050 -
Read out fault memory of the airbag control unit
18058 -
Data bus drive
  Missing message from combiinstrument
t  Datalines faulty
t  wrong or defective dash panel insert
t  incorrect or defective engine control unit
18061 -
Read out fault memory of the ABS control unit
t  Fault in ABS control unit
t  no vehicle dynamic control
t  TCS not operational
t  MSR not operational
–  Check ABS control unit → Chassis → Rep. Gr.45.
18062 -
Read out fault memory of the combi-instrument
t  Oil level and oil temperature sender -G266 - defective
t  Oil level warning light lights up
–  Check oil level and oil temperature sender -G266- → Current flow diagrams and Fitting locations.
18065 -
Air conditioning system inlet/outlet
–  Check air conditioning system → Chapter.
18067 -
Radiator fan control 1
–  Check blower relay -J323- → Chapter.
18080 -
t  Line interruption
t  Relay defective
18090 -
Data bus drive
  implausible signal from ABS control unit
t  Databus lines to ABS control unit interrupted
18259 18057
Data bus drive
  Missing message from ABS control unit
t  Faults in the databus lines to ABS control unit
–  Check databus lines to engine control unit for open circuit or short-circuit → Current flow diagrams and Fitting locations.
t  Fault in ABS system
18262 18056
Data bus drive
  Hardware
defective if necessary
defective
65535 16989
17795
18048
Control unit defective
t  Control unit internally defective
t  Engine stoppage
Thanks everyone.
It all helps with the diagnosis and joining up the dots.
Think I will probably have to get the car relayed to a VAG expert for more detailed and practical tests.
Martin
Preliminary checks show the cam belt and turbo appear to be OK.  My hunch is that sediment has collected at the bottom of the fuel tank over time and has caused a fuel blockage. The fact that the fuel gauge jumped from just above the red low zone to nearly a third of a tank suggests the possibility that some of this sediment may have also caused an artifical pressure reading.
Off to an independent VAG man as soon as he has a spare slot.
Martin
