312 brakes and the fabia servo
Im thinking about taking the leap into 312 audi TT brakes. I've went through all the prior threads reqarding mod and cannot find the answer to my following question.
Over time will the Fabia vRS break servo be able to withstand the increased effort of moving the larger calipers from the Audi TT? Also is there any change in brake wear under normal driving conditions i.e. are the TT pads softer and need changing sooner that std fabia pads.
The piston size is exactly the same so there is no more effort in activating the brakes.
Pad wear should be comprable to standard.
thanks for the quick reply
