Skoda Dog Guard Fitting Pack
Okay so for anyone buying the Trunk Grille (5E9 071 195) for the MK3 Octavia Estate, a "fitting pack" is needed.
This comes with the trunk grille if you buy new from a dealer, but doesn't if buy used. This is because 4 rivets need to be riveted to the car. See below manual:
http://eshop.skoda-auto.com/wcsstore/B2CStore/Attachment/Soubory ke stažení/5E9 071 195-MN-1595.pdf
Fitting pack part no: 5E9 017 737. When I contacted my local dealer, no Skoda dealer in the UK had this in stock so had to be ordered from Czech Republic.
img_0574-jpg.109106
I didn't use any of the specialist tools that Skoda list, but bought a riveting tool off eBay for the job:
http://www.ebay.co.uk/itm/M8-Engineers-Heavy-Duty-High-Tensile-10-9-Rivnut-Insert-Setting-Tool-Nutsert/122666523090
Edited by jordy_wd
Formatting
Genuine part from another Mk3 estate, however it only came with the four screws in the picture!
Edited by BlueDiesel
Yep that's exactly the same as mine came - what a hassle!
The four holes are already in the car. The headlining needs drilled and also plastic in the boot area.
The holes are hard to find - I ended up peeling back the headlining.
Is a fitting kit required then?
It is yes. It contains 4 spacers, 4 rivnuts, and the 4 screw knobs you already have too. You'll also need a tool to secure the rivnuts into the car.
How much was the fitting kit?
£23 incl. VAT
On 15/09/2017 at 16:59, jordy_wd said:
£23 incl. VAT
Where can I get one from mate? Can’t find one anywhere online.
I had to go to my local dealer who had to order from the Czech Republic.
Thanks for all of your help mate, you have been awesome. Skoda are ordering me one also, I'm just not looking forward to trying to fit it!
I have a copy of the template that shows where the top holes need to go, I'll dig it out and scan it to pdf then post it up on here.
The lower holes have a small mark in the plastic to show you where they need to go.
Does anyone know if a VW Golf mk7 Estate dog guard would fit the Skoda Estate??
Have you got the part number for it?
No. Guess I'll find out when I get the car. Thought they might be similar being VAG. The VW one is just secured by a thin piece of metal that hooks onto the catch which locks the back seats in the upright position.
They are very different in appearance and, as you state, fitting arrangement is also different. Would be surprised if the golf one were compatible with the Octy.
Here you go, template to mark the hole to be drilled into the headlining.
The rule is to give you a scale, but I have printed it off on A4 and checked it against the original.
Hope it helps out.
Dog_Template.pdf
Am I missing something here?  You can get a brand new Octavia Mk3 Estate dog guard from Travail which comes with all the fittings and no riveting required. They do one for estates with or without sunroofs as they are slightly different. I have had mine for about a year now and they fit really well, solid and sturdy. I did lose one of the tiny rubber feet  when I took it out  and Travail sent me 2 spares free of charge.
Update: Clearly I was missing something, you already had the guard from ebay!
Edited by Maynarb
update
img_0574-jpg.109106
Thank you so much, this is incredibly useful !
Hope it helps out.
Dog_Template.pdf
Just fitted my Octavia dog grill with the help of your pattern thanks. (it's not an easy job). The addition of a ruler is inspired and allowed a scaling adjustment to be made on the printed template. With my printer it worked out about 3mm longer and about half a mill wider.  Use a ruler to measure the printed ruler to get your own scale.  The holes ended up absolutely exactly in the right place, more so than the pre-marked holes in the plastic sides which were slightly off (but OK).   Another tip is when drilling the head-lining, use your drill slowly IN REVERSE to avoid snagging the material. Also, if you're using the nut and bolt method to set your rivnuts you'll need a 130mm M8 bolt and a bag of washers (or home-made spacer) to extend through the headlining.
Hope it helps out.
Dog_Template.pdf
Done it.
Would have really struggled with this template, so thank you again !
Hope it helps out.
Dog_Template.pdf
Any chance you could send me the dog template please,
[email protected]
  • 2 years later...
Hi cmalc, I just tried using the nut and bolt method today on the side ‘trunk lining’ first before embarking on the ceiling ones. I’ve really struggled to get the rivnut to expand into the hole, I think it is spinning but not 100% because it’s all a bit out of sight behind the linings. Any more tips if you can remember!?
  • 3 years later...
A thread resurrection from me.
I too bought a the genuine Skoda dog guard off ebay, it too came with the finger bolt things and nothing else. I found this thread, ordered the fitting kit direct and I've just fitted the lower mountings. To stop the inserts spinning I used an impact gun and a few nuts as spacers. This works.
I'm dreading the top mounts, I'll print off the template and report back.
P.S. a bit of advice to anyone who sees a used genuine Skoda dog guard on eBay, just don't buy it unless you have a car with the mountings already installed.
It's all done and hoovered up.
The template shared by a previous poster worked perfectly, I adjust the scale prior to printing to 107% and it matched the A4 outline exactly. I pushed a black biro through the centre mark and transferred it to the head lining. I used a small cross head screwdriver to puncture the lining and I could the outline of the blank hole behind it. A quick buzz through with a 19mm hole saw and everything was aligned.
Thank you previous posters who took the time and effort to share your expiernces.
