Bigger Injectors
Hi
I was just wandering if anyone knew if you can put different PD Injectors into my 05 Fabia Vrs. With the likes of 150PD injectors or 160PD Injectors would it be a straight fit or even work ??
On 8/25/2017 at 17:28, Stephenmc said:
Hi
Hi, from memory I think they are the same injectors in the higher output pd engines - I think they flow enough to produce 220 'ish bhp with a larger turbo.
That's great thanks very much
