Electrical problems.
My Fabia from 2011 have a strange problem.
Sometimes when i start it, the ac, highbeam, powerwindows and the fan does not work.
But, if i loosen the steeringwhell and slide it back and forward and upp and down, it starts to work, sometimes.
Is there som kind of switch or something there thats  is the problem.
Or does anybody have an idea what the problem could be?
The body control module is located down in that area as well as the fuse box just below.
Not sure what your fault could be though.
Edit: i would suggest checking the wires in the door checks since it's a common area for failing, might start helping you go in the right direction
Edited by hutchysrs50
