Amundsen+ vs RNS 315
What are the pros and cons of picking either an Amundsen+ or an RNS315 from a VW or Seat? Is it just a case of the illumination not matching the dash?
I'm on a fairly tight budget, and the RNS models do seem to go for less money than the Skoda versions.
I've currently got a Bolero (as well as a spare Joying Android unit), but I fancy something OEM that can do Bluetooth (for Spotify), navigation, DAB and reversing camera.
Thanks.
RNS315 / Amundsen+ have variations within the theme as well.......optional are DAB, BT and RVC. (Nac is standard) Either model can have 1, 2 or all three options.
Other than that: yes, the illumination, menu colour and boot logo, are the only differences. (VCDS is not able to change this either.) Functionality is 100% identical.
Make sure you get the GPS receiver, and if you got a BT model, get the microphone too. (And or a DAB aerial if you get a DAB one.)
You'll need new trim as well, as those units are squarer than the Bolero.
Also, updating the maps is a case of selling a kidney too.
...And you cant hack them for free maps either.
or Speed Cameras (free or paid) - which in particular is what I disliked about it.
Pick a Columbus / RNS510 instead.
Edited by camelspyyder
You can copy both RNS-310 and RNS-315 map SD cards.
For example, I bought a genuine map SD for an RNS-310, decided that 8GB was too small, then copied the maps to a larger 32GB SD card for more music space. The RNS-315 involves an extra step but is also possible.
I think the OP was asking about Amundsen+. I had that and it was locked down. No free upgrades or cameras. Once the genuine card has been in one machine I don't believe it will copy for use in another HU.
I would ask @Rustynuts. Knows lots of this stuff.
It is possible to clone an genuine SD card before it's used on the RNS-315/Amundsen+. It's not just copying the files though...
I'm sure you can find more using google but I doubt I can post more here.
Thanks for the info.
I loved using Google Maps on my Android unit, so going to OEM nav with the annoying update situation might be a bit of a shock!
I could always go back to using the phone in a cradle for nav, but would still want rear view camera, built in Bluetooth and DAB from the unit.
