Spare Wheel Tray and related question
Hi Guys,
Does anyone know where you can get the styrene/foam storage tray at sensible money ?
I have seen the Spacesaver wheels for sale, but not the tray without spending silly money.
Normally I would spec it at order, but as I didn't spec the car I don't have a spare. Being old school, I would be happier knowing I have one :blush
Also does a full size spare fit ?
Unless you are getting a variable boot floor, and keep it at the highest level, then a full size wheel (same size as your regular wheels) won't fit. if you want a genuine steel spare, as you're getting a 280, you need a special space saver that will clear the 280's larger brakes. Other models get away with a 16" wheel that is a reasonably meaty size. The special one for the 280 is a larger diameter, comparatively skinny space saver.
  • Thanks 1
^ Yes, I specced a spare. It's an 18" skinny steel spacesaver.
Didn't get the variable boot floor.
Thing is, I kind of remember thinking I was speccing a full size spare which is why I couldn't have the variable boot floor. Not having either is a bit of a minor miff...
Kind of want to put a full size Vega in there...if it'll fit.
Cheers :)
I thought there was some foam on the outside but as there isn't I have just ordered a 18" SS wheel and tool kit from ebay.
Of course, I doubt it comes with the plastic topped bolt to fix it down with, wonder where I can get the part no. for the holding nut ? !
