Very hard ride
Can anyone advise me on my problem . He ride in my 2014 Octavia black edition is very harsh. The suspension transmits every bump through the car. I am on Bridgestone tyres and wonder if I can improve the ride by fitting softer tyrs. 225 / 40 / 18. / 92  Y.
Bridgestone tyres are quite a hard tyre from my experience. Stiff sidewalls too. I wouldn't replace the tyres prematurely, but once they are done grab some Goodyears, Continentals or Michelins and they should be better.
With that tyre size presumably you have a VRS, so don't expect a huge transformation in ride quality from changing tyre - it does have "sports" suspension i.e. Quite a stiff ride and relatively low profile tyres don't help either.
Edited by ahenners
Black Editions weren't Vrs's. They were one off but I think they had sports Suspension and 18" wheels. Think there were 2 engine options 1.6L & 2.0L Diesel and only 2 colours, Black or White.
Edited by Auric Goldfinger
I've just fitted slightly wider 235/35/19 Michelin Pilot Supersports and I'm convinced the ride is better. The sidewalls are slightly taller, being 35 profile of 235 width rather than 225. It could be my imagination though. May be an option to fit 235/40/18's? Speedo is still within tolerances.
DOH... Missed that bit about black edition. It's early :tongueout:
Just for you Sir   :coffee:   Black, no sugar
So that'll be 40 profile tyres & a rear torsion beam suspension with a sports setup
Hmmm firm & crashy you say, I wonder why?
Yes, on rough ish roads I feel every bump. The suspension is set up as sports I think. My query is which tyres are softer than Bridgestone S001's
cheers for any thoughts
Thank you; that's just how I like it!
Look for the lowest noise levels you can get, Eagle F1A3 are quite, Michelin Cross Climates too & useful if you get snowfall
Thank you, I was considering the goodyear ISO 3 but someone also suggested Yokohama advance sport v105s so not sure which ones?
I'd seriously consider 17"s if you have the cash. And then at least a 45 sidewall. The difference in ride on my A2 between harsh 195/50 summers and 185/60 winters is like night and day.
 - Bret
You should check that the front suspension transport blocks have been removed and also consider changing the rear shocks to ones from the Golf Mk 7, direct 3-bolt swap and with softer damping characteristics.
