Bulb in Heated Rear Window Switch
Hi all,
The heated rear window switch in my Octi doesn't illuminate which means it's often left on unnecessarily. Can you get into the switch to change a bulb or whatever to get it going again?
Normski.
@Normski55 - @nige8021 is correct; that's an LED and not a bulb.
Thanks for your feedback guys, much appreciated. If its an LED, can that be replaced? I wouldn't be able to do it but there are some electronic gurus where I work that might help.
Normski
If you can solder ? then you should be able to replace it, might be cheaper/quicker to see if you can get one from someone breaking one @Purpletom is breaking one
