Source for additional Switches
Hi,
I want to add some extra switches for some equipment and have been looking but not been able to find spare switches that will fit in the switch panel below the Belero unit (where the ESP and Off-Road switches are)
Are they just generic switches or are they special Skoda or VAG switches?
Sean
Specific Skoda.
Thanks for that Llanigraham, I will see which online Skoda store carries them then or ask next week when the YETI goes into the main dealer as the Exhaust Emissions Sensor has come on on the dashboard.
I see some chap in Denmark on eBay has several of these switches but really expensive at £60'ish
If you put "Breaking Skoda" into the Ebay search box you'll probably come up with suitable and more affordable possibilities.
Most car manufacturers use similar switches across some models. Worth a shot.
Be sure that the switch you get is fit for the purpose you want to use it for, ie I'm sure some will switch a current and others normally open just send a pulse whilst pressed.
