Boot/Door Locking
I have noticed, annoyingly, that when I close the boot (sometimes not always) on my Yeti the car automatically locks all the other doors as well - not great when you are loading the boot at the supermarket and it's chucking it down.
It only happens occasionally, not always.  Has anyone else experienced this and is there a way to prevent it happening?
Thanks.
You sure you are not opening the car with the middle key on the fob? If so, this is exactly how it is meant to work
As above, which button are you using to unlock the boot?
Yep, as everyone above has said. You’ve got to remember not to drop your keys in the boot as you put anything in by mistake. You then shut the boot & your locked out.
Sorry for the delay in replying.  It doesn't seem to matter which button on the remote I use the issue is the same.
For example if I use the 'open all' button then open the boot lid manually the same thing happens.  Ditto with the boot unlock button.
If "Open all on the fob" and only the rear hatch is opened and closed the other 4 doors will remain unlocked.
If the middle button is pressed and the hatch is opened and closed it will lock the hatch after a few seconds, all other doors remain locked throughout.
Thanks.
It could be that the opening of the boot is not detected correctly and hence auto locking the doors again after 30 seconds.
Could it be the remote fob? Try using the spare one for a while to see if it behaves differently.  Any chance you could be accidentally pushing both Unlock All and Boot Only buttons at the same time?
