Ecu change?
My vrs 130pd wont start faulty immobiliser if i change the ecu kit
The clocks key chip and reader and the ecu is it just plug and play the new ecu is of a asz eninge aswell
The immobiliser, from memory is linked to the instrument cluster so to use another ECU you'd have to have the matching cluster and key from the same car.
Yes i have the key the cluster the ecu and the key reader
You will have to get the mileage on the replacement cluster altered to your actual mileage.
Will it work apart from that
It should do.
