Rear Wiper - intermittent/continious wipe
Evening and daft question #327.
We have a MY2017 L&K Yeti, and I have a question re the operation of the rear wiper.
Does it only work in an intermittent wipe pattern? ... I'm sure I have had it working in a continuous wipe before, but failed over the weekend in dreadful weather to have it wipe continuously it only wiped intermittently.
I have tried "auto" mode enabled and disabled in maxi-dot (seems to be an automatic intermittent mode,) the owners manual suggests the 3 stalk positions are  .... OFF, rear screen wiping (doesn't mention intermittent nor continuous operation,) and spraying and wiping.
So did I imaging there is a continuous wipe function, or do I have something set that's preventing continuous wipe?
Clear as mud ...,?
Lying down in a dark room seems like a good option.
No, only intermittent unless you hold the switch to spray the screen
OK thanks I must have imagined the continuous wipe. :)
