Retro fitting Driver Alert System (Fatigue detection) on Pre FL Octavia
11 minutes ago, sarfraz1997 said:
Hi, I have a 2011 Mk6 Jetta (5C). I have enabled Fatigue Detection in CAN Gateway and Pause Recommendation in the Instruments. But I'm not able to get the assistants menu in the MFD or the fatigue detection system. Upon checking the measuring blocks, I have a Fatigue Detection Fault Code "4.0" too. I am attaching a VCDS scan of my car. Could you pls help me out on how to proceed?
Saturday,09,May,2020,20:45:38:59248
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWK11160CA551350   License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWK11160CA551350   Mileage: 90070km-55966miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CLCB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 GJ    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H25 9977
   Revision: 42H25---    Serial number: 00000000000000
   Coding: 001D0012042500080000
   Shop #: WSC 12704 938 00000
   ASAM Dataset: EV_ECM20TDI01103L906018GJ 003006
   ROD: EV_ECM20TDI01103L906018GJ.rod
   VCID: 78FF37A4C3343B8AE5-802C
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2706
   Revision: 05351113    Serial number: 00001107250497
   Coding: 0000020
   Shop #: WSC 00047 000 00000
   VCID: 173D1418266AD4F20C-8042
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: A63B40F8092700FB650E02E990190082250800
   Shop #: WSC 00047 123 12345
   VCID: 7BF528A8FA02109288-802E
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0507
   Revision: 00001015
   Coding: 0000001002
   Shop #: WSC 00047 000 00090
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_VW32.rod
   VCID: 7F0DDCB8E61A0CB2A4-802A
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 06000A38F82900C0C0080080140081EC07F1008850A08120DC8040040040
   Shop #: WSC 00066 123 12345
   VCID: 3B75E8A8BA82D092C8-806E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 050811 05  54  0403
   Coding: 07300A
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 84091116401870
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71E90A80A04E6AC222-8024
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
   Component: AirbagVW10G   013 0613
   Serial number: 003G7RA0J2ZX
   Coding: 00003241
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3365C0889AD218D210-8066
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME646F0542ZZZZ
   Crash sensor for side airbag: front passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME7C750542ZZZ-
   Crash sensor for side airbag: rear: driver side:
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME291D1E13ZZZX
   Crash sensor for side airbag: rear: passenger side:
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME531C3712ZZZO
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110726300620
   Coding: 0892140000
   Shop #: WSC 00047 123 00090
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E3399CC9204DFAF7-8022
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5C6 920 871 A    HW: 5C6 920 871 A
   Component: KOMBI         H04 0617
   Coding: 171B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: 2A5BDDEC4D18591AA3-807E
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 210711F1000786
   Coding: 351003
   VCID: 3561FE909CA606E23E-8060
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0617
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB1DEC8D98991A63-803E
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0516
   Revision: 12110009    Serial number: 0002922906
   Coding: 0012B7
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
   VCID: 1C370B34174CB7AA21-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1508
   Serial number: 00000005878191
   Coding: 000290
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3467C39457DC1FEA09-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0516
   Revision: 14110009    Serial number: 0002892582
   Coding: 0012B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
   VCID: 1D3106300C56BEA2D6-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1508
   Serial number: 00000005956442
   Coding: 000290
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5522
   Revision: --------    Serial number: VWZ7Z2T3107373
   Coding: 0E000400000000
   Shop #: WSC 01234 785 00200
   VCID: 49998260E05E72024A-801C
End-------------------------(Elapsed Time: 02:28)--------------------------
You should have appropriate parameter file for gateway.
Refer this for more detailshttps://www.drive2.ru/l/8674505/
Edited by virgo79
I tried visiting and understanding but, I could not comprehend or understand anything that guy has written. Would you pls be able to explain in layman terms?
Check ur PM
  • 3 months later...
Hy. I already retrofited driver fatigue function but i have a problem. When the function is active, the image with coffee break and the gong doesnt appear, but in vcds store the error for initialised driver fatigue function. My car is a skoda octavia 2 facelift. I changed already can (AN), cluster (Q), write the parametrization file, i have assistance menu in maxidot.
In can gateway on driver fatigue measurements, doenst store error code (appear 0).
What is the problem?
Thx in advance and sorry for my bad english.
