Retro fitting Driver Alert System (Fatigue detection) on Pre FL Octavia
Hi,
I have Pre FL Octavia 2 and I have upgraded my instrument cluster to 1Z0 920 843 S and CAN gateway to 7N0 907 530 AN.
Below is my VCDS log.
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 843 S    HW: 1Z0 920 843 S
   Component: KOMBI         H06 0608
   Serial number: 00000000000000
   Coding: 110E01
   Shop #: WSC 73430 031 00083
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 489ED584F3671F0602-801C
No fault code found.
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 061213F1002209
   Coding: 351303
   Shop #: WSC 73430 790 12345
   VCID: 7CF67954FF3F83A6D6-8028
I have enabled fatigue detection in CAN gateway and have enabled pause recommendation in instrument cluster, still cannot see  DAS in assistance menu of cluster.
May i missing something? some component or coding? and how to test if DAS is working?
Thanks.
Got a full VCDS autoscan?
Does that gateway support fatigue detection? It might need flashing to add it.
You might also find the ABS and power steering modules need updating or replacing.
Here is my full auto scan
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 25 36 42 44 46 47 52 55 56
          62 72
VIN:   Mileage: 156670km-97350miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 LB    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000AG  9251
   Revision: --H07---    Serial number: SKZ7Z0G4313907
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 6ADA4F0C45AB0D1634-803E
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 044 G    HW: 02E 927 770 AE
   Component: GSG DSG         081 1404
   Revision: 04608010    Serial number: 00000705160223
   Coding: 0000020
   VCID: 193840C0D04D568E6D-804C
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0005249
   VCID: 73E452681261CCDE87-8026
1 Fault Found:
01486 - System Function Test Activated
            000 -  -
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 5K0 907 044 EK    HW: 5K0 907 044 EK
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 73430 790 00999
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 78FE6544C307AF86B2-802C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005009614
   Coding: E1028E111004140000110D000000000000087F065C000000000000000000
   VCID: 71E85860687DFECE75-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 050607 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     010707 046  0204
   Coding: 00471077
   Shop #: WSC 73430
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 56D 919 475 A    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0006
   Revision: --------    Serial number: 35821404003728
   Coding: 100101
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_EPHVA18VW4110000 001007
   ROD: EV_EPHVA18VW4110000.rod
   VCID: 336492689AE18CDE47-8066
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 156675 km
                    Date: 2017.10.16
                    Time: 09:09:34
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AA    HW: 1K0 909 605 AA
   Component: Q3 AIRBAG VW8   027 0900
   Revision: 11027000    Serial number: 003B5D128VK8
   Coding: 0020787
   VCID: 6BD44A084A51141E4F-803E
   Subsystem 1 - Serial number: 6332MSME173C651BH
   Subsystem 2 - Serial number: 6342MSME1C13626DG
   Subsystem 3 - Serial number: 6351HSME0F220A253
   Subsystem 4 - Serial number: 6361HSME0F1643715
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0101633
   VCID: 7AFA7F4C350BBD96C4-802E
   Subsystem 1 - Part No: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0012
   Coding: 00000131
   Shop #: WSC 00000
   Coding: 110E01
   Coding: 351303
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RAYD606
   Coding: 0000002
   VCID: 7EF2735C292391B6F8-802A
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H06 0608
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADA4F0C8DAB0D1634-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F6C9E18BEC9A83E23-807A
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 E    HW: 1T0 959 701 E
   Component: Tuer-SG         006 1204
   Coding: 0001014
   VCID: 3978A040708D768E8D-806C
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 3662AB7C419399F660-8062
Address 46: Central Conv.        Labels:. 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 98801A085283007F3F020F0FC008DFD6907C00
   Shop #: WSC 00046 000 00000
   VCID: 030402A842C1FC5E97-8056
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H05 1501
   Subsystem 2 - Part No: 5J0 951 172
   Component: DWA-Sensor      H03 1211
   Subsystem 3 - Part No: 5J0 951 172
Address 47: Sound System        Labels: 1Z0-035-456.lbl
   Part No SW: 1Z0 035 456     HW: 532 226 800
   Component: SK35-DSP        4   1000
   Revision:   4         Serial number: 00029700
   Coding: 0000000001
   VCID: 72EA576C6D7BC5D68C-8026
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 E    HW: 1T0 959 702 E
   Coding: 0001014
   VCID: 3A7ABF4C758B7D9684-806E
Address 55: Headlight Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000007
   VCID: 74E65174176FCBE69E-8020
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 156 D    HW: 1Z0 035 156 D
   Component: Radio FO3       004 0011
   Revision: 00004000    Serial number: SKZ7Z4G0001824
   Coding: 0000020
   VCID: 3364926852E18CDE47-8066
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377CA678469960FE7B-8062
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012550
Is there any output test for DAS?
Looking at that, I think you'd need:
- a new ABS pump, MK60EC1 rather than MK60
- a new power steering rack, gen3 rather than gen2
I have no idea if anything else would need changing as I've not seen anyone try this on a pre-FL.
You can check the measuring blocks of the CAN gateway, assuming everything is good it should look like this:
I would expect there to be a non zero fault code shown in group 6 in your car.
Attached is my screenshot, I see 4 in error code
Issue fixed by flashing CAN gateway SW to 7N0907530BL and applying parameter file.
All credit to langers2k :thumbup:, wouldn't have been possible without his help.
Attached is my measuring block post upgrade.
How did u flash can gateway . And what is the parameter file? Are u referring to old coding values
On 11/22/2017 at 00:06, langers2k said:
@Harrytech - Google is your friend, https://www.drive2.ru/l/8674505/
Continue at your own risk, flashing always has it's dangers...
I tried flashing but it retains my original SW even after successful session .. any idea why?
Post a full autoscan and what are you using to flash?
Any screenshots etc might be useful...
Using Odis engineering. I have AK as stock .. flashed it with AN 1642 sgo. Though post flash the identification still showed AK. I chose to run the parameters file anyways and it worked. Not sure why version was still AK.
On Channel 6 i have no Errors under fatigue detection fault code. But my Channel 8 fatigue detection sw version is same pre and post flash (3330).
Here is the result after i ran the parameter file and tested with VCDS Fatigue test on Canbus. (Earlier it use to say channel not supported)
Edited by Harrytech
additional info
That's normal.
As listed on the drive2 page:
- E, AB, AF, AK rev will become AK.
- AA, AE, AJ, AN rev will become AN.
If doesn't make any difference as long as the SW version is 1642, the suffix will change depending on the hardware of the gateway.
3 minutes ago, langers2k said:
That's normal.
so you are saying all the above will support MKE? i understood the drive2 page as:
a. Stock canbus 7N0907530AF Ver 1635 to be flashed to 7N0907530AJ Ver 1635
b. Stock 7N0907530AT Ver 1663 to be flashed to 7N0907530BC Ver 1663
c. Stock 7N0907530AK Ver 1642 to be flashed to 7N0907530AN Ver 1642 (THIS IS MY FILE)
d. Stock 7N0907530AL Ver 1642 to be flashed to 7N0907530AN Ver 1642
e. Stock 7N0907530AM Ver 1642 to be flashed to 7N0907530AN Ver 1642
did i understand wrong?
I'm saying that there is one flash file (AN 1642 sgo) which can be used to update many gateways to SW:1642. The part number after flashing will depend on the hardware inside the gateway. In your case, a AK gateway H57, it will never become a AN gateway H52.
Your AK gateway was already running SW:1642. There was no need to flash the AN 1642 sgo, you just needed the dataset XML flashing...
The fatigue detection software version won't change as it's running the same software (1642) as before the flash, all you've done is enabled MKE ;)
SUPER!
just to understand it clearly and also help my friends - suppose some one has 7N0907530H ver 1620 and  7N0907530AE ver1633 which Sgo should be applied? this example will help me understand it clearly.
also is it possible to do this in MQB Octavia 5E
Address 19: CAN Gateway (J533)       Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
Component: GW MQB High   128 1265
Sorry to bug you so much
Based on the drive2 page:
- 7N0907530H takes 7N0907530AJ_1635.sgo
- 7N0907530AE takes 7N0907530AN_1642.sgo
Both should support MKE after the flash and dataset have been completed.
These files aren't suitable for MQB cars. To enabled MKE on these, you'll need a dealer to activate a FeC/SWaP code.
AK is a low version
AN is a high version
you can't make a low version into a high version
both versions support MKE
Awesome .. thanks a million
On 11/24/2017 at 17:03, Eddie-NL said:
AK is a low version
Is AL a high version or low version?
Where can I find this kind of info?
if you have the gateway
go in adaptions and see if you can enable extended can
I ordered a AN gateway, but instead I got an AL. I'm asking because I intend to install PLA 2.0, RVC, MKE, TPMS, OPS and I want to know if AL gateway supports all of these functions.
Edited by dan_irinel
extended can (high version) only required for high tpms
All that so you can get a cup of tea pop up on your screen??! :blink:
  • 2 years later...
Hi, I have a 2011 Mk6 Jetta (5C). I have enabled Fatigue Detection in CAN Gateway and Pause Recommendation in the Instruments. But I'm not able to get the assistants menu in the MFD or the fatigue detection system. Upon checking the measuring blocks, I have a Fatigue Detection Fault Code "4.0" too. I am attaching a VCDS scan of my car. Could you pls help me out on how to proceed?
Saturday,09,May,2020,20:45:38:59248
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWK11160CA551350   License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWK11160CA551350   Mileage: 90070km-55966miles
03-ABS Brakes -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
Address 01: Engine (J623-CLCB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 GJ    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H25 9977
   Revision: 42H25---    Serial number: 00000000000000
   Coding: 001D0012042500080000
   Shop #: WSC 12704 938 00000
   ASAM Dataset: EV_ECM20TDI01103L906018GJ 003006
   ROD: EV_ECM20TDI01103L906018GJ.rod
   VCID: 78FF37A4C3343B8AE5-802C
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2706
   Revision: 05351113    Serial number: 00001107250497
   Coding: 0000020
   Shop #: WSC 00047 000 00000
   VCID: 173D1418266AD4F20C-8042
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: A63B40F8092700FB650E02E990190082250800
   Shop #: WSC 00047 123 12345
   VCID: 7BF528A8FA02109288-802E
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0507
   Revision: 00001015
   Coding: 0000001002
   Shop #: WSC 00047 000 00090
   ASAM Dataset: EV_ACManueBHBVW36X A01010
   ROD: EV_ACManueBHBVW36X_VW32.rod
   VCID: 7F0DDCB8E61A0CB2A4-802A
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 06000A38F82900C0C0080080140081EC07F1008850A08120DC8040040040
   Shop #: WSC 00066 123 12345
   VCID: 3B75E8A8BA82D092C8-806E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 050811 05  54  0403
   Coding: 07300A
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 84091116401870
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71E90A80A04E6AC222-8024
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
   Component: AirbagVW10G   013 0613
   Serial number: 003G7RA0J2ZX
   Coding: 00003241
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3365C0889AD218D210-8066
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME646F0542ZZZZ
   Crash sensor for side airbag: front passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME7C750542ZZZ-
   Crash sensor for side airbag: rear: driver side:
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME291D1E13ZZZX
   Crash sensor for side airbag: rear: passenger side:
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME531C3712ZZZO
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110726300620
   Coding: 0892140000
   Shop #: WSC 00047 123 00090
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E3399CC9204DFAF7-8022
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5C6 920 871 A    HW: 5C6 920 871 A
   Component: KOMBI         H04 0617
   Coding: 171B00
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
   VCID: 2A5BDDEC4D18591AA3-807E
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 210711F1000786
   Coding: 351003
   VCID: 3561FE909CA606E23E-8060
   Component: IMMO          H04 0617
   Serial number:
   Coding: 000000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB1DEC8D98991A63-803E
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0516
   Revision: 12110009    Serial number: 0002922906
   Coding: 0012B7
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
   VCID: 1C370B34174CB7AA21-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1508
   Serial number: 00000005878191
   Coding: 000290
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 3467C39457DC1FEA09-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0516
   Revision: 14110009    Serial number: 0002892582
   Coding: 0012B6
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
   VCID: 1D3106300C56BEA2D6-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1508
   Serial number: 00000005956442
   Coding: 000290
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5522
   Revision: --------    Serial number: VWZ7Z2T3107373
   Coding: 0E000400000000
   Shop #: WSC 01234 785 00200
   VCID: 49998260E05E72024A-801C
End-------------------------(Elapsed Time: 02:28)--------------------------
Also, my Fatigue Detection Software Version is 204
