Floor Mats, manual vs DSG.
Can someone please tell me in there a difference in the floor mats for a manual vs DSG Octavia VRS combi. Looked on Superskoda and it doesn’t appear to offer two options. Common sense would suggest there should be.  Many thanks.
The mats are the same regardless of DSG/manual and hatch/estate
Thanks a mill
Got the mats for mine last month from Skoda Parts Ireland/Burns €100 for all rubber mats and mudguards.
Google Photos Album Link
Th
Thanks again, are the mud flaps easily fitted. i could be considered a little ham fisted with the tools.  Thanks
54 minutes ago, Peter'ssuperb said:
Th
Drill one hole in each side for the fronts (not as ominous as it sounds) and can be done with full opposite lock. Rears don't require any drilling, just a couple of screws undoing and putting back. Probably takes an hour or two but relatively straightforward.
Can also vouch for Skoda Parts Ireland, that's where I got the mudflaps from as they were so much cheaper than UK sources.
6 hours ago, Peter'ssuperb said:
Th
Quite easy, I took the front wheels off to make the access easier but in the end it was a satisfying job to do and definitely got easier as I went along. All in it probably took an hour and a half.
