Help sourcing brake nipples
Hey this is meant to be the brake nipples but discountined part ?
6Q0615273
Had a search about - Is this effectively the same do you think ? ( not bad for a set)
https://www.ebay.co.uk/itm/VW-POLO-2001-2009-FRONT-AND-REAR-CALIPER-BLEED-NIPPLES-SCREWS-NIP2038K/231018233696?fits=Car+Make%3AVW|Model%3APolo&hash=item35c9c27f60:g:1CoAAOSwPGlZ4NGW
According to the allocation of the part would suggest it is.....
http://www.oemepc.com/tvn_result/search/tvn/6Q0615273
may have fun getting the old one out though, might have to wack a socket on it or something
Dude they're standard metric bleed nipples as fitted to HUNDREDS of millions of cars, they're nothing special, M10 x 1.0.
Try here:
https://brakeparts.co.uk/
I thought so and quoted GSF but they just said "discountinued main dealer" even when I quoted the pitch etc. Thanks for that.
Holy hell that site makes others seem so unprofessional. I literally now found that part in seconds compared to others that have nothing.
Amazing, thanks.
GSF are morons and are not surviving the relentless onslaught from eurocarparts, my local branch just closed down.
BTW the link I posted and company you posted are identical as are the Fabia/ Polo part numbers on it :D
I wouldn't have known this information if you hadn't confirmed it though, and had no idea the polos would work until you confirmed their site.
The ebay ad is cheaper so recommend people use that one as you get 4 for £5 posted but it was like £4.50 for just front 2 with postage - HTH
For any brake parts I use these guys http://www.biggred.co.uk/  first class service every time I've used them
