Fuel Door Drain Blocked
Hi,
The little water drain hole behind the fuel door seems to have stopped working?
Anyone know where / how this runs? Is it a common fault? Or easy to fix?
Don't want to randomly poke something down until I know more - would hate to split the pipe somewhere sensitive.
Cheers!
Just vents out into the wheel arch. Nothing scientific or special - mine used to do it every now and again.
Just poke it with a paper clip or something similar.
As Coops says.
When I wash my car I simply squirt the hose at it if the water is not or is slow to drain this usually clears it. If not I use an instrument screwdriver just to clear the first inch or so as that is where I have found the blockage is.
