Choosing a polisher
Hi guys,
I finally decided to give up on going to a detailer but instead start doing it myself.
On that note I firstly need to buy a DA polisher ( no question about rotary at all) but I'm a bit confused on how to choose.
I've narrowed down on a griots garage flex and Bosch but the thing is except Bosch I will have to import the rest.
While digging deeper I figured that the rpm range on the Bosch is 350-3500rpm .
My question is would this be sufficient to remove swirls and etching due to bird dropping.
I do have prior experience using a polisher but never bought one.
Hence the ask.
Hi,
Cant comment on the bosch but did u consider a das6 or das6pro polisher? Im very happy with mine (does everything you need it too)
Yes, I have looked at that as well.
But my problem is sourcing these.
Sourcing das6 was tougher than gritos, hence I've didn't look much into it
Hi rkhshm, try these 2 sites for your machine polisher.
Clean your car
Polished bliss
Both very good sites and hopefully accommodate you.
Das-6 Pro on eBay...
262253237719
Took me all of two seconds to find one and took me longer to edit out my fat finger post :D
Edited by jars
Hopefully he will find a company/person willing to ship to India.
your right. I need it to be shipped to india.
Most of the polishers are predominantly getting shipped from US.
100$ polisher is costing me another 120$ to ship it to india :D
Oh no rkhshm, that's bad news. Hopefully someone at clean your car or polished bliss can help you. Good luck :)
Aliexpress to the rescue and i picked up a polisher.
Wanted to try out a new brand (at least that's what i think it is) called 'clover'.
Some pads are also on the way.
I"ve picked up orange, red, white(CCS) pads as well.
Its been 2 yrs since i did any detailing on my car and I see a lot of swirls and hence the efforts.
I'm confused about  picking up a good 1 step polish, any help on this please?
I"m looking at Meguir's M205 , and i believe the M205 with an orange pad should be ample to really cut out the general swirls.
Any opinions guys?
I'd use the equivalent of chemical guys hexlogic orange pad for the megs 205. I do believe scholl concepts do a really good one step polish now that cuts, then polishes once the product breaks down. Might be worth a look if that's the route you want to take.
Yeah the orange pad I've taken is equivalent to CG hex pads.
Let me check out between m205 and scholl .
But are there any other 1 step polishes you suggest?
Hi  rkhshm, I've slipped up. I would use CG guys white pad with the megs 205, and the orange pad for use with the megs 105. Sorry about that. My bad. As for other one steps, hopefully another member might be able to help out.
No problems.
Thanks for your opinions
There are many specific products to polish your  car. I always use mafra products.
They are leaders in Italy and their products are very good. If you want, you can try it. check this product out!
