fabia mkI: Temperatur flap has a life on its own - more questions.
Hello all.
I've been reading a lot of posts on the subject of faulty temperature settings, but I still could use your help on this:
Car: Skoda Fabia 1.2 htp 2003
My temp flap is all over the place - which seems to be a common problem. I've installed a used flap motor but it didn't solve my problem. I'm beginning to wonder if the potmeter in the temp control panel is faulty?
It doesn't seem to respond when I turn the knop - only when I go all the way to the left (cold).
If I turn it towards warm, it gets very warm after just a few clicks.
I hooked the car up to my laptop and read the values as I turned the knob about a bit - and filmed it.
Link to video: https://youtu.be/enLD1s8gAYw
The specified value on the potentiometer G92 does not match my movements at all - would you think that the potentiometer in the knob is bad?
IS the G92 under the control knob?
Is it possible that a VCDS reset could do the trick?
Any other ideas?
All tips/advice are appreciated - thank you.
Best wishes -
Kasper, Denmark
I think you have adapt the new motor using VCDS.
  • Sponsor
@Kapper The G92 potentiometer is part of the V68 motor module, not part of the control module. There may not be a direct relationship between the temperature control knob and the G92 pot demanded position.
It's certainly worth adapting the control module to the replacement motor module, but it may be that you have been unlucky and fitted a V68 that isn't healthy.
Thank you
Edited by Kapper
pasted wrong text
