Help please! Fabia Vrs mk1 intercooler pipes popping off
Little help please.
After servicing and cleaning the all the pipes from the egr and the intercooler through to the turbo.
I'm having difficulty keeping the pipe attached that links from the top plastic pipe to the rubber pipe that attached to the intercooler.
It holds to about 3k then pop.
I've had it off numerous times and this is the only time it won't stay
Chances are the lugs have worn front the pipe which is causing it to pop off. A few self tapper screws is the common fix for the pipes popping off, or a slightly modified mikalor clamp.
Thank you!
  • 3 months later...
Pipes all secure now. Built in situ on the dining table. Self tap screw and glued up too. Thank you
