Dash Clock Swap
Hi All I have got a set of Octavia 1 L&K Clocks and was wondering if they were a straight swap into an octavia ambiance I know the immobilizer would need programing I did unplug my clocks and plug the new clocks in to see what happened they did work but i got bulb failure, airbag fault and the windscreen washer light came on (im guessing i could wire the sensor up)  ???
Also is there anyone who has got an L&K Complete heated seat wiring loom available ? I would pay up to £70 for please inbox me!!
The lights failure washer low level can be coded out if you have VCDS the airbag might just be you a power interruption fault code that you can erase
Should they just slot straight in though ? The Pins wont be different ?
What about the bulb failure will the ambiance support that ?
They are a straight swop the pins are all the same just some won't be connected in your wiring.
If you want to keep the bulb failure feature you will need to do quite a bit of rewiring and fit the bulb failure module in the relay panel tbh its easier to just code it out so you don't get the warnings, mine keeps giving a brake light fail warning but they are all working OK its a nice feature but can be a pain when it gives false warnings and if you try fitting LED rear light bulbs it doesn't recognise them and again puts on the warning message
