pd160 intake pipe
is there any "how to guides" on the forum for the fitment of the pd160 intake pipe ,part numbers and prices also would be useful . does this pipe make a lot of difference to the performance and is it essential to use it with a kn,green or jetex filter .
A search should furnish you with all your answers.
now worked out how to search the forums , doh . seems like its about £24 and the part numbers i've seen are for the euro spec parts which may chaff on a coolant hose ,didn't find any actual dyno figures did anybody do a dyno run ?
Takes 2 mins to do. Panel flter change 2 mins too. Yes it makes a difference to top end pull. Better with a remap
As for bhp - nope no difference although you can rev higher more easily so that helps :)
Is the PD160 intake the same part number for the octavia TDI 110 (sorry to ask)
ta , but what i was asking is will the PD160 air intake fit a TDI 110 engine in an octy
