Octavia FL Strange electrical problem
Strange things have been happening to our Octavia and gotten worse this year. At the beginning the cluster stoped working for maybe 1second during driving (happened a couple of times after this). Next thing that happened is that I got a left AFS error. This error disappeared by itself.
Next strange thing is that I got a left fog light error and after that left brake light error. These errors also disappeared after a day or two. (Both works fine now)
Yesterday I got an EGR fault putting the car in limb mode, so I put the car in a warm garage. Today after clearing errors, it hasnt come back. Anyone with these kinds of errors? Or anyone knows why left side is affected?
Its a swedish car, driver on left side.
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 69 72
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
   Revision: --H43---    Serial number:
   Coding: 00114016032400080000
   Shop #: WSC 73430 031 00090
   ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
   ROD: EV_ECM16TDI02103L906023LP.rod
   VCID: 7F071D25E6E65D1
1 Fault Found:
7462 - EGR Valve (N18)
          P0403 00 [101] - Malfunction
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 30139 km
                    Date: 2077.14.29
                    Time: 11:17:27
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 113B201C09250002881104E4901C0041300000
   Shop #: WSC 73430 790 00090
   VCID: 75EBFF0DDCDA171
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_SK35.rod
   VCID: 76E9F801C9DC1C9
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40000AB8E049F1C040080080510091E4437000AE726D85605C8540000040
   VCID: 387536398B48AA9
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 12031  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 210311 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor 03   03 1109
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
5 Faults Found:
01134 - Alarm Horn (H12)
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 62
                    Mileage: 194369 km
                    Time Indication: 0
                    Date: 2012.14.08
                    Time: 13:31:05
             Freeze Frame:
                        Term 15 Off
                    Voltage: 14.15 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
00987 - Lamp for Brake Light; Left (M9)
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 1
                    Fault Frequency: 7
                    Reset counter: 65
                    Mileage: 197080 km
                    Time Indication: 0
                    Date: 2013.14.10
                    Time: 15:36:39
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 197696 km
                    Time Indication: 0
                    Date: 2013.14.19
                    Time: 16:44:29
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.45 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 80
                    Mileage: 197734 km
                    Time Indication: 0
                    Date: 2013.14.21
                    Time: 09:31:34
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.40 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 197734 km
                    Time Indication: 0
                    Date: 2013.14.21
                    Time: 09:37:34
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901107001452
   Coding: 11800E
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_SK35.rod
   VCID: 336F01159A2E491
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC24SX3W
   Coding: 0020790
   VCID: 3D7B272D646A8F1
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110318300074
   Coding: 1082140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWSXS_SK35.rod
   VCID: 79F3F33DF8C2731
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 843 M    HW: 1Z0 920 843 M
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 110E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 428154D1D594F09
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 200311F1001921
   Coding: 352302
   VCID: 30650E196338729
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   VCID: EAD15C710D64489
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0546
   Revision: A1001003    Serial number: 7663203521
   Coding: 030100
   VCID: 2A511C7145E4089
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0000246
   VCID: 76E9F80101DC1C9
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            012 - Electrical Fault in Circuit
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 346D020957204E9
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000246
   VCID: 489546F93BA8DA9
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1507354
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000023
Address 56: Radio (J503)       Labels: None
   Part No SW: 1Z0 035 161 N    HW: 1Z0 035 161 N
   Component: Radio-SWING   012 0036
   Revision: -----16S    Serial number: SKZ4Z2L1176346
   Coding: 0D0004000001
   VCID: 3973333DB042B31
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012570
   VCID: 32610411AD34409
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00000144898855
   Coding: 410D000100000000
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F0115522E491
End   ---------------------------------------------------------------------
Edited by ke84
How old is the battery? If its around 5 years might need replacing.
It could be the battery but these are quite specific errors.
Have you changed a bulb recently? First thing I would be checking is the connector to left light cluster is properly pushed home. And also that there is no water ingress.
I suspect the EGR fault is a separate issue. On the pre FL diesel its relatively easy to remove and clean the EGR valve, can't imagine its that different on the FL.
Edited by adamal
Typo
Just checked under the hood, and cables on the left side are completely soaked, so I think that may be the issue. After some heavy rain tonight the egr problem returned when I drove to work, but's now gone again. Really getting confused.
Where is the solenoid egr-valve connector located? (not the egr cooler, but the electrical connector, maybe i'm getting a short)
The battery is about 7 years old.
The bulb started to work again, so there was no need to change it. Still works.
Edited by ke84
Someone will hopefully be along with the answer for a FL, but if not post a picture of the engine bay with the cover removed and it should be possible to point it out...
