Center of the dash makeing noises
it never happend in my old fabia, and every other fabia i've been in hasnt creaked in the center of the dash where the middle airevents are, anyone know how to stop it from makeing that really annoying noise?
Bit of silicon sealant fixed mine but the dash was off at the time which made it much easier to apply. :D
Chris
thanks! where is it though? i want to stop it im guessing thats all you know :(
I think this has been extensively covered before...
If you prise out the centre air vents with a rubber tipped screwdriver you will see the dash mount, it is this that makes the noise.
Silicoln or cut up bicycle inner tube or simmilar wedged in behind it will cure it. :thumbup:
Now get on MSN... ;)
If you prise out the centre air vents with a rubber tipped screwdriver you will see the dash mount' date=' it is this that makes the noise.
Now get on MSN... ;)[/quote']
Ta:D
