Help needed with new caliper
So I'm needing some advice/help. I have just replaced my front right caliper the car is a mk2 fl vrs. After connecting the brake pipe to the new caliper the it doesn't seem to be sealing properly as it is leaking brake fluid. Does anyone know should there be a washer or something between the connection that screws into the caliper and the caliper. I'm starting to think that there should be and mines might be still be on the old caliper that is already with europarts. Any help will be appreciated.
Thanks Mark
Yes there should be an alloy washer between the banjo bolt and the caliper.
Thanks micmac I thought that was the case.I'll need to go buy some washers tomorrow then
That's it all sorted now no more leaking brake fluid
