Washer Fluid In Rear Footwell
I have washer liquid in my rear passenger footwell!
Can anyone tell me where the pipe can be found, and what trim needs to be removed to get to it.
Many thanks!!!!!!:eek:
The fluid still gets to the rear window so it must be a small leak
Its the plastic trim that runs in front of the rear arch, between the door seal and the seat.
The connection just comes aparts slightly, giving fluid to the washer, however sparying fluid inside the trim, which runs down in to the footwell.
When you clip it back together it might be worth assisting it to ensure it doesn't come apart again by using some glue or bind the joint in tape.
