TPMS Fault
Hi,
This DTC pooped up on Skoda Octavia 1.4 TSI 2014
c1146f2
what is it ?
Where are you seeing this?
Launch
TPMS EEPROM fault.
I'm sorry, I don't know.  Can you provide more details?  someone else will help.  What diagnostic system are you using?
what happened is I changed the the coding the ABS to add ESC sport option
I used VCDS to read DTC
it was exactly this on
C1146f2: Tyre Pressure Dispalay-EEPROM Mulfunctioning
I hope this is a sufficient details
I suggest you go to the Ross-tech support forum and post an autoscan.
I don't have access to Ross tech mate, I think it is not original vcds.
any other forum you can recommend ?
No.  You are on your own now.
& this is why you are having problems with the mod I posted that you did.....if you have a MK3 Octavia newer than 2013/2014 which is a MQB platform the rip off VCDS cables will only work with the free older Rosstech software.....which does NOT work properly with the MQB platform cars & anything newer....
I agree, I have thrown it to trash and ordered genuine one.
thank you very much mate.
just want to report that problem is solved by disconnecting the battery for ten minutes and connect again, in case somebody faced it in the future
