mk 1 LED DRL light wiring.
Probably simple instructions.
I have a set of drl LED's with wiring, it states that they must be wired into the headlights.... but how? Id like to have them wired into the '0' position light switch.... so that they are on when the light switch is at 0, and off on all other terms. I managed this on a polo 6R but forgot to save the format.
1.9sdi, getting 540 actual miles per full tank of diesel.
I had a set of phillips wired to my Fabia, but they were auto sensing for "On" so were on all the time in "O" position....off I had two wires one for MOT & one for driving MOT has changed now...but basically used the side lights & dipped beam positive feeds as the two "off" sensing wires for the DRLs....so ran with the DRLS on & on in sidelight position as brighter than the sidelights, but off when dipped & main beam...
