1.6 tdi intake temp sensor location.
Could someone please point me in the direction of the intake air temp sensor for the 1.6tdi engine. Its fault code is p0111 and always displaying on the plug in reader that it is 266deg whether it is hot or cold.
Thank you for the info I assume it's on the pipe running down the front of the engine do you know if it is visible from the engine bay or is it only from underneath as I simply can't see it thank you
