How to save door mirror position?
Hi, New to the forum and new to Skoda ownership.
So far, I'm really enjoying the car (Superb Sportline 220) but I can't get the door mirror positions to save. I thought I had saved my settings to my driver profile but each time I get in the car, the driver mirror is pointing to the floor and passenger side points to the sky.
Does anyone know how to save the positions?
Aarron
Hi Aarron and welcome. Do you have electric seat adjustment? If so, the seat and mirror position is set using the buttons on the right hand side of the seat base. When you get it how you want it, IIRC press "set" then one of the numbers. When you hear a bong, it should be set.
If it's the same as my Octavia 230 once the mirror/seat is set to the required positions you need to turn off the ignition, key out, open drivers door, press " Set " then position " 1, 2, or 3 " until you hear a " bong "
I do have the electric seats - Pressing set and a number didn't seem to do anything, so I'll try the above.
When you say 'key out', I have keyless start, so do you mean remove the key from the car?
I too have keyless. Set it up, press 'set' then press and hold down the number until you hear the bong. That should do the trick.
Thanks - Will give it a go this afternoon
I would think in your case its just a matter of turning the Engine/Ignition off, but I think the door has to be open when setting the memory positions
Edited by Auric Goldfinger
Quite tricky whilst doing 70mph down a busy motorway! :blink:
It is fun though, I find if you hog the middle lane you can open both front doors....................
Not on mine from memory AG.
