Brake Pad Part Numbers
Hi.  I need new rear pads, and according to by PR code list, i have 1KF rear discs.  It's a pre-fl 2005 Combi 140ps TD PDI (BKD), which I believe means it has 260mm rear discs.  Can anyone tell me the part number for the pads I need?  I'd prefer a set with the shims & bolts, so getting ones for the correct thickness of disc would be useful, although if you can only give me a number for a pad set, that would do.
Thanks.
My wife's got the elegance combi 05 and I've put these discs and pads on this time from a motor factor JCP 1083 pads and VAG136 discs.
Most retailers should be able to do the work for you when specifying registration number.
All you need consider is price/performance.
Thanks.
Quote
Unfortunately MicMac, my car always comes up as a lower-powered 8v, not a 140PS 16v, which often gives the wrong brake part numbers.
Cryonut - Thanks, that sorted me out.
