Headlight levelling motor
The right headlight unit on my Roomster is making a loud ticking  noise while the adjuster wheel is set on ”neutral”. If i adjust the the wheel a bit (as when fully loaded/heavy towing) the noise stops.
Sounds like this could be caused by a faulty light levelling motor, right?
Anyone knows if this motor is even replacable on the Roomster and if the motor is the same as on the Fabias from around the same year (2007)? Cant fine any part number...
Sounds like the motor could be trying to operate when the light is on the stops. Perhaps the limit switch is a bit out. If it works normally over most of it's range, why not live with it?
