Change Throttle Response
I have a '09 MKII superb and want to get better response from the throttle. I see that you can change the coding on a MKIII via obd eleven, but ive seen nothing regarding a MKII.
Has anyone changed the throttle response on a  MKII with obd eleven? Or know the correct coding ?
If some knows the code from VCDS I could mach with obd eleven.
11 minutes ago, penguin17 said:
I've just been discussing this with a mate and he has just sent me the following link.  I'm familiar with the 'Audi throttle mod' via VCDS/OBDEleven as I've used it myself (I didn't notice a difference) but I've never come across this before.
It may be worth a go:
https://www.reddit.com/r/Volkswagen/comments/2k18h9/psa_reset_your_throttle_for_better_throttle/
How did you manage to do the mod. What year is your superb?
Mine is a S3, MY17.  I used OBDEleven, no long coding required.  I just looked at the VCDS 'how to' and then mirrored that, just navigating to the relevant controller and sub menu(s).  It was fairly intuitive.
I've also had it done via VCDS on a Mk 3 Leon FR which was a MY13.
It might be worth checking the OBDEleven forum:
Nothing on the OBDEleven forum, only guide is for the NP model. I will try and look at VCDS and give it a go.
Perhaps ask in here and then see if there's an equivalent OBDEleven function for yours:
https://www.briskoda.net/forums/forum/23-diagnostics-amp-vcds/
Ok will do
No way to do this on the MK2 I'm afraid, it's a limitation of the ECU rather than VCDS or OBDeleven.
Only options are either a remap or peddle box :)
Ah ok thanks
I'l get a pedal box
