Chris
Car not  starting  or trying  turn good battery
So you have a "good" battery you say ...
Does it crank anyway?
Serviced properly?
Any fault codes stored and which should be diagnosed ?
What happens when you turn the key?
When I turn  the dash lights  come on nothing  else  happening
Engine  code11447 can't  find this  anywhere anyone  help thanks
Not sure that's a valid fault code, at least it doesn't seem to appear online.
You might want to try a different fault code reader, ideally something like VCDS.
Do dash lights dim when the key is turned? Can you here the starter motor trying to turn?  Might need to get close as someone turns the key... Listen for clicks/whirrs. Don't rely on hearing it from the cabin.
Have you undertaken any other work recently?  You say battery good. Is this for sure? A new battery will be no better then an old one if flat, a dying battery, although saying it is charged on a charger, will be very weak so might not operate AT ALL!
If you are new to the car you may not know that the clutch needs to depressed to start the car. If still the same, check there is nothing obviously wrong with the clutch pedal switch. Next step is to get a diagnostic report.
Battery  out of my own skoda octavia lights  don't  dim no clecking not turning  over  nothing  happens  at all
You'll definitely need VCDS to scan it properly man..
Something it will show surely.
