Knock sensor
Hi can any one tell me if my 1999 Skoda Felicia 1.3 MPI has a knock sensor if so where is it located on the engine.
I purchased a genuine Skoda knock sensor in the Skoda box it has a single bolt fitting in the centre with the intention of changing mine as my car is 20 years old and I do like to change things at the moment the car is running perfect no problems.
Also should I change the MAP sensor on the intake or just leave well alone.
I purchased car new and have no intention of changing it just to give it a lot of T.L.C
Yes, it has. It is located on the back side of the engine block.
Note: tighten the bolt to exactly 20 Nm.
"If it ain't broke, don't fix it."
Thanks RicardoM for the reply.
Don't get going anywhere as I may need you in the next 20 years.
Next stop will be Ireland or the UK.
Knock sensor at back gearbox side plate over it....
Good morning.
