Swapping 1.6TDI Engine with 2.0 VRS TDI engine
Oh well
ill deal with it when it comes to that :cool:
  • Replies 52
  • Views 28.9k
  • You could spend thousands upgrading the 1.6's engine, gearbox, suspension and brakes.   Then it will cost you more to insure a modified car and any reliability issues.   And then y
  • Sounds to me like your instinct is wrong on the entry level Octavia if that is what you have and the vRS Brakes and Suspension.   Look at the Project Builds on in Briskoda where Yeti, Fabia
  • SashaGrace
    SashaGrace
    If you were to do it, you’d need the engine, a gearbox to match, the front brakes are larger and the rear subframe is different as the vRS has independent rear suspension over the standard cars torsio
14 minutes ago, AMD87 said:
Oh well
Indeed , likewise with my owned from new 17 year old Octavia which has an Engine Management Light showing and a bit of an oil leak. Fortunately it's still MOT'd until March. Shame because the body is mint
Edited by bigjohn
13 hours ago, bigjohn said:
DPF delete? - MOT has just changed to spot this. It's also a up to a £1000 fine to drive with one deleted (er if caught!).
There is a garage near us with a large sign outside offering DPF delete and MOT's. Wonder how long they will remain in business.
