How to remove rear door card?
I am going to try to seal the plate that holds the window mechanism, to try to stop water getting into the Furby (as suggested by Lummox). I will need to remove the rear door cards. Can't see any screws. Could anyone who has done this please advise?
The front section of the handle/armrest pops up and the back section slides forward revealing some phillips screws. There is a small torx screw behind the tweeter grill. Remove the winder handle by sliding the collar behind the handle up and pull the handle off. Then pop the bottom out and lift the whole trim upwards and off.
To really seal the carriers they need to be removed though.
I will have silicone sealant gun ready! Thanks as always.
Is this the same for the front door cards??
Near enough, just on the front there are three small torx screws along the bottom.
Cheers Hopefully i wont break anything on this mess around session.
